How to update IBA value without object checkout and checkin
Participant
I do have IBA attribute field on the wizard table. I want to update that attribute without check out and checkin object.
I have tried using following code for that. But getting error message that "Design is not checked out and cannot be modified".
object.load("XXXXX","YYYY","ZZZ");
  /* Set value of IBAName soft attribute to IBAValue */
  object.set("XXXX", strCNo);
  object.set("YYY", strCS);
  object.set("ZZZ", strAS);
  perObj = object.apply();
  perObj = (Persistable) PersistenceHelper.manager.modify(perObj);
7 REPLIES 7
Re: How to update IBA value without object checkout and checkin
Hi Binesh,
Appreciate your prompt response. I will try to evaluate the mentioned package. It would be great if you help with some pseudo code if any.
I got workaround for this: below is the code
PersistableAdapter  perAdap = new PersistableAdapter(perObj, null, Locale.US, new UpdateOperationIdentifier());
  perAdap.load("XXXX");
  perAdap.set("XXXX", str);
  perObj= perAdap.apply();
You need to persist your modifications :
The following code does what you want and uses the PersistableAdapter.
A direct use of IBAValueDBService may be prohibited by the thought police...
import com.ptc.core.lwc.server.PersistableAdapter
import com.ptc.core.meta.common.UpdateOperationIdentifier
import wt.fc.Persistable
import wt.fc.PersistenceServerHelper
import wt.iba.value.DefaultAttributeContainer
import wt.iba.value.service.IBAValueDBService
import wt.part.WTPart
WTPart p;
PersistableAdapter obj = new PersistableAdapter(p, null, Locale.US, new UpdateOperationIdentifier());
obj.load("SOUS_CHAPITRE");
obj.set("SOUS_CHAPITRE", "Ploum, ploum, tra-la-la");
p = (WTPart)obj.apply();
// Here is the trick
IBAValueDBService ibaserv = new IBAValueDBService();
ibaserv.updateAttributeContainer(p, ((DefaultAttributeContainer)p.getAttributeContainer()).getConstraintParameter(),null,null);
PersistenceServerHelper.manager.update((Persistable)p);
thanks olivier for your prompt help and support.
Please suggest a way to update values on the EPM Document too. As current code is showing some issue like: "Attribute values cannot be added, removed, or changed"
Yes, EPMDocuments cannot be managed with this API.
You need to use EPMWorkspaceHelper.manager.setAttributes, as described in the link below.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS110292&art_lang=en&posno=5&q=EPMWorkspace...
Some limitations :
  • You need to do a checkout/checkin in a workspace.
  • If you have a family table, you have to checkout the whole family table.
Thingworx Navigate content has a new home! Click here to access the new Thingworx Navigate forum! ______________________________ Check out the Windchill Tips Board! We're talking about Whirlpool's use of digital twin, augmented reality, and data-driven design!
The NAVIGATE WORKING GROUP is here! Come innovate with PTC!
Sign up for a Working Group
