How to upload tif images into windchill ?
hsuryaprakash
Hi
How to upload tif images into windchill ? And how to integrate tif image drawings with corresponding cad models ?
Hi! Try this.
Go to to the representations snd annotations tab of the cad document info page. In the representations and annotations table you may create new default representation like follow:
In the second step chhose your tiff file and submit publish job.
One of the following may also apply to you, depending on your situation.
If the TIFF image directly describes the BOM item.
  • needs it own document number.
  • should be lifecycle managed.
  • required version/change control
then create a describing document and add the TIFF as primary content.
If the TIFF image is derived from your CAD file then you can add it to the EPM Document as an attachment. The CAD Doc has to be checked out to a WGM workspace to do this. By default I believe the attachment will carry forward when the CAD Document is iterated. If you don't want that to happen (then don't forget to remove or replace the attachment on subsiquent versions of the CAD Doc.
http://support.ptc.com/cs/help/windchill_hc/wc101_hc/index.jspx?id=CADxInfoPageActionsAttachmtEdit&action=show
As yu said is right .My tif image will carry forward the cad doc iteration.Whenever change is happened in cad doc ,the iteration of both should be updated .If possible ,pls take screenshot & dispaly
