I want to add Check-IN comments through code.
apatil-2
I want to add Check-In comments to an existing object without Iterating it. Is there any way to do that? Snipet would be really helpful.
Not sure if this is in 10.1. See if VersionControlHelper.setNote exists and does what you want. Save with the Persistence server helper
Hi Matthew first of all sorry for late reply was busy in other task.
I checked the API its working .
VersionControlHelper.setNote(doc, "Comment");
PersistenceServerHelper.update(doc);
Thanks a lot..
