I want to append generic name with instance only if 2 generics having same instance
V_B_THAKARE
6-Contributor
Hi @HelesicPetr@Hari_Vara & @Hari_Varadh,
Version: Windchill 12.0
Use Case: Used case: Add preference "include.genericname.with.instance=Yes" in the wgmclient.ini file. But due to this it is appending generic name for each and every instance of Family Table.
Description:
Expected output: If Family Table instances having more than one top-generic only in this case it should
                                  append the generic name in instance.
Can you show an example of this? There is a limit to naming so I can see if you wanted it to have all generics listed, it would be a problem? Is this a feature of other CAD system to have more than one top level generic?
