IBA value updated two times
hsha1102
I have implemented a logic where an IBA attribute of WTDocument will get updated at certain point in a change task workflow.
But for one object the IBA attribute is updated two times which is causing some issues in the upcoming activity nodes.
For example: If the attribute name of a document is "Info" and the value I am trying to persist is "value", when the IBA updation logic is executed the value is coming as "value","value".
I can see two entry in the database in String Value table for the document.
Can anyone please shed some light on this?
Thanks and Regards,
Hari R
0 REPLIES 0
