Hey Chris, you mention sending a file for watermark.
I have just started trying to get watermarking working. I followed the wvs guide, ptc knowledge base tan's/tpi's, video, etc & cant get it to work.
I posted my files on post: http://portal.ptcuser.org/p/fo/st/thread=53830
If you dont mind, maybe you can send me your file(s) [ini & server_prefs.xml] &/or look at the files I attached at that post & see where I might have messed up. the ini & xml are there, along with a couple images that show vis cfg admin page, mapping, etc.
I would appreciate any help.
If you email yours, please email datajett@aol.com, because I check it more often than the email connected to ptcuser.
Larry Jett
