Import WT.Part with spreadsheet
Alberto
Hello, I'd import a mass file to chage some attributes (custom attributes, string type) on a specific wt.part.
If I try to import an exitsting without cad documents, the import is done but if the wt.part has a cad documents the import failure. Do you have an idea?
MikeLockwood
22-Sapphire I
(To:Alberto)
Please see attached example of successful import from spreadsheet for a WTPart with associated CAD Doc.
Must be something to investigate related to the value(s) entered the spreadsheet that wouldn't validate.
Thanks a lot for your reply, I'll check your information 😉
I tried your solution but nothing, same issue.
The procedure works only when the parts never had a cad document assigned.
MikeLockwood
22-Sapphire I
(To:Alberto)
Happy to look at what is happening on a meeting if you want.
Set up with: mikelockwood1@hotmail.com
