In Workflow Editor, Start flag and robots are not visible.
vuchekar
In Windchill 10.1M040,
when i opens a Workflow editor window, in editor window shows blank.
when i put robots in it , it not visible, but when randomly click on screen, it opens respective pop up window.
Please see, below image.
How to fix this ?
Vivek
10 REPLIES 10
This has probably something to do with your graphic card driver.
Try to set these parameters in your java settings:
-Dsun.java2d.d3d=false -Dsun.java2d.noddraw=true
Go to Java Plug-in > Java Control Panel > Java > Java Runtime Environment > User
Hello Björn Rüegg,
Thanks for yoyr reply.
I tried the suggested settings, but no luck.
Still it opens a blank editor window.
Vivek
Have you closed all the java exe's or restarted the computer?
Yes,
I took machine restart.
Vivek
Did you delete the Java temporary files? Also, what version of Java are you running?
Did clearing the cache solve the problem?
If not, are you running this in a VM? If so, try to disable in the VM settings the direct support of the graphic card.
Hello Björn Rüegg,
I dhad cleared all cache, take a restart but issue is still their.
No, I am not using VM.
My current java version is : 1.7.0_65.
now i am updating my java version to java 8, and check once again.
once it finish i will update you on same.
Vivek
After updating Java, now java version is 1.8.0_25
Facing below issue, while opening workflow applets only.
all other appletes are working fine.
basic: Told clients applet is started
>> IN getSelectedWfTemplates OR:wt.inf.container.ExchangeContainer:101
>>>> IN WfTemplatesAction.run OR:wt.inf.container.ExchangeContainer:101
>>>> OUT WfTemplatesAction.run OR:wt.inf.container.ExchangeContainer:101
>> OUT getSelectedWfTemplates OR:wt.inf.container.ExchangeContainer:101
network: Cache entry not found [url: http://uchekar1.asiapacific.hpqcorp.net/crossdomain.xml, version: null]
network: Connecting http://uchekar1.asiapacific.hpqcorp.net/crossdomain.xml with proxy=DIRECT
Exception in thread "Thread-13" java.security.AccessControlException: access denied (java.net.SocketPermission uchekar1.asiapacific.hpqcorp.net:5003 connect,resolve)
at java.security.AccessControlContext.checkPermission(Unknown Source)
at java.security.AccessController.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkPermission(Unknown Source)
at java.lang.SecurityManager.checkConnect(Unknown Source)
at sun.plugin2.applet.Applet2SecurityManager.checkConnect(Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.checkConnectPermission(Unknown Source)
at sun.rmi.transport.tcp.TCPChannel.newConnection(Unknown Source)
at sun.rmi.server.UnicastRef.invoke(Unknown Source)
at wt.method.MethodServerImpl_Stub.invoke(Unknown Source)
at wt.method.RemoteMethodServer.invoke(RemoteMethodServer.java:647)
at wt.services.ServiceFactory$ClientInvocationHandler.invoke(ServiceFactory.java:349)
at com.sun.proxy.$Proxy6.getObject(Unknown Source)
at wt.fc.DefaultInflator$CorCache.inflate(DefaultInflator.java:409)
at wt.fc.DefaultInflator$CorCache.inflate(DefaultInflator.java:397)
at wt.fc.DefaultInflator$AbstractCache.get(DefaultInflator.java:291)
at wt.fc.DefaultInflator$AbstractCache.get(DefaultInflator.java:259)
at wt.fc.DefaultInflator.get(DefaultInflator.java:135)
at wt.fc.CachedObjectReference.getObject(CachedObjectReference.java:201)
at wt.clients.workflow.definer.Util.getContext(Util.java:373)
at wt.clients.workflow.definer.WfProcessTemplateTaskDelegate.isCreateAllowed(WfProcessTemplateTaskDelegate.java:287)
at wt.clients.workflow.definer.WfProcessTemplateTaskDelegate.launchCreateTask(WfProcessTemplateTaskDelegate.java:92)
at wt.clients.workflow.definer.WfTemplateEditorApplet$NewThread.run(WfTemplateEditorApplet.java:257)
Java 8 is still not supported. This won't work.
jessh
(To:BjoernRueegg)
Well, more accurately Java 8 is not supported.
If you enable RMI tunneling, a lot of applet functionality will work, but there certainly are things that won't work.
10.2 M030 will support Java 8 clients.
