Install Windchill 9.1 error
ptc-2121234
A Fatal Uninstall Exception has occurred during cleanup java.io.FileNotFoundException: C:\Documents and Settings\Administrator\Local Settings\Temp\removefils.txt (Access Deny.) at java.io.FileOutputStream.open(Native Method) at java.io.FileOutputStream.<init>(FileOutputStream.java:179) at java.io.FileOutputStream.<init>(FileOutputStream.java:131) at ZeroGdv.b(DashoA10*..) at ZeroGdv.a(DashoA10*..) at com.zerog.ia.installer.LifeCycleManager.d(DashoA10*..) at com.zerog.ia.installer.LifeCycleManager.a(DashoA10*..) at com.zerog.ia.installer.LifeCycleManager.b(DashoA10*..) at com.zerog.ia.installer.LifeCycleManager.a(DashoA10*..) at com.zerog.ia.installer.LifeCycleManager.a(DashoA10*..) at com.zerog.ia.installer.Main.main(DashoA10*..) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at com.zerog.lax.LAX.launch(DashoA10*..) at com.zerog.lax.LAX.main(DashoA10*..)
Please see if you have access to C:\Documents and Settings\Administrator\Local Settings\Temp Dir. only admins can install a Windchill Solutions. get admin access & fire the PSI again.
Also check if you Temp Dir is set in Envirnoment Variables or not.
