Installation Problem
kpitchaiah
2-Explorer
Will run through the steps which I followed to install windchill 11 please help me out
1)Install and configure oracle in other system
2)Run PSI and link to oracle
3)Check all prerequisite and install windchill 11
4)Installation Aborts by following error
5)Checked log file it shows as follows
Guys please help facing these issues on installation
java.lang.Exception: Return code was: 1.
PSI aborts with java.lang.Exception: Return code was 1 because of No disk space for Windchill PDMLink
DescriptionPSI aborts with java.lang.Exception: Return code was 1 because of No disk space
Applies To
  • Windchill PDMLink 11.0 M020
Cause
Resolution
  • Reported to R&D as SPR 6376828
  • Workaround:
    • Increase the disk space and re-run PSI
‌Could you attach the entire MS log?
Can you also try to provide full permission to the user through which you are launching the PSI and try again.
