David,
All I know is that unless we have the following config.pro setting
save_instance_accelerator=explicit
then we have check-in problems when assemblies contain family table memebers.
Regards
I'm hoping to acquire some knowledge for this topic also. What are the pros and cons? We have a PTCcase open and the recommendation is to create instance accelerators. (If you are creating light weight viewables from a Windchill publisher and do not create instance accelerators, then a possible performance impact canhappen. In our case, it is10-15% impact.)
The concerns we have experienced in the past:
1) File Size
2) Extra File to Manage
3) Issues with Windchill/Creo workspace interactions. (no specific details but might havebeen related to checkin, assemble, or replace)
4) The impact with"Marked as modified, but untouched" instances when users open assemblies in Creo.
Below are thebest practices and config options recommended from PTC. The setting for outdated accelerator is new in Creo 2 M030. This one may resolve many of the concerns from the past.
Bill Ryan
Peterbilt Motors Company
Hi Dave,
If you still need an answer for this? Our Family table instances were regenerating when we open an assembly.
This is from PTC Tech support. . You need to login as Librarian of Admin
The instance accelerators are actually saved in the detail page under "content: for each instance.
The user then must update their Workspaces if they have any existing family items checked out.
Larry Ensler
Lyncean Technologies Inc
