Upon connecting to my server the internal browser never repopulates with my chosen workspace, it remains a blank white screen. I am connected as I can open files using the ribbon and verify it through the server manager.
I was recently given a new (faster) machine that was giving me 'the server is unavailable" errors, which was corrected by setting Google as my home page for the browser. Once I click on Workspace in the tree I then connect to my server and the white screen appears.
I'm on IE10 already & mozilla is already my default browser
Creo r2.0-M070
WIndchill r10.1-M040
I've seen something similar before. If you switch to a non-active workspace you may be able to see the contents but the active workspace remains blank or never fully loads. The solution we found was - in a standalone Internet Explorer browser - to select Tools > Internet Options > General (tab). Under the Browsing History section select the Settings button and pick the radio button for 'Every time I visit the webpage'. Restart Creo and the active workspace appears. Not sure how you would set this in Firefox but basically we are disabling/bypassing browser caching when we set this.
Another possibility is to update Creo 2.0 to M100 or later and use the config.pro optionbrowser_limit_to_ie9_mode yes. This config.pro option supports Internet Explorer 10.0. See knowledge base article CS171233 for details.
Hello Regan.
We are experiencing similar behavior with our intranet sites in the internal browser. A workaround that usually helps is simply to open a new tab in the internal browser and to close it – and all of a sudden the initial tab shows its content…
HTH
Matthias.
