Fellow 'chillers,
I doubt I am the first to ask yet a quick search of the Forum archives came up empty..., so I shall ask (again?).
I was sent a .stp file from a client. I want to import that.stp file into my Windchill-based Intralink 10.0 workspace.
However, when I go to my Workspace and perform a Tools>Import to Workspace, navigate to the hard drive location of the target .stp file, the .stp file is not listed. The resulting dialog only wants to list .prt, .asm, and other native ProE file types.
And if I type the name of the target .stp file into the dialog box then click Open, then I am given an error within ProE: Invalid Extension.
Sooooo..., the question is, "How do I import a .stp file into my Workspace?"
Is there something in Windchill I need to config or define first? It would seem that .stp would be an extension Windchill would recognize OOTB, but I've been wrong about similar assumptions before.
TIA,
Scott
WF4 / Intralink 10.0
Thanks to all that replied.
The universally-suggested config.pro setting worked as advertised:
allow_import_file_extension stp
On to the next bump in the road...
Cheers and thanks again,
Scott
