Intralink 8/9 Replication
Highlighted
Hello all,
I've not gotten to use or test Intralink 8/9 yet so I do not know all of the functionality of the software. One question that did come up though that I did not know the answer to and that was how replication works. With Intralink 3.3, you can replicatea copy of your files to another site, but you cannot have more than one file server on a machine and you cannot combine dataservers. If you want to get to a different dataserver you have to point your client to the new dataserver and should have a different set of workspaces. Is this the same in 8/9? Or can you connect multiple "dataservers"? Can you mirror/replicate multiple dataservers into one?
Thank you,
Brian Toussaint
CAD Administrator
Highlighted
Summary: Intralink 8/9 Replication
The answer is you can replicate your servers. You can easily point to
one or the other. You cannot merge the dataservers.
Thank you to Kory.
Sincerely,
Brian Toussaint
CAD Administrator
