Community Tip - If community subscription notifications are filling up your inbox you can set up a daily digest and get all your notifications in a single email.
X
Check that at least one folder in External Storage Administrator/Vault Confituration is not marked "Read Only" (e.g., column labeled Read Only has a "-").
When you have disk space issues, Windchill will mark the folders read only, so you have to manually change them back once you take care of the issue.
