Intralink 9.1: Moving CAD Part to a Different Product
ScottPearson
3-Newcomer
Hello Wizards,
Is it permissible to MOVE an object in (Windchill) Intralink 9.1 from a Folder in ProductA to a Folder in ProductB (a different "Product" Context but the same "Organization" Context)?
At first glance, it doesn't look like an allowable option. The reason I say this is that when performing a MOVE on an object, the resulting dialog box only lists the Folders in ProductA. And though there is a drop-down box called "Context", it greyed out. (See attached .jpg.)
FYI, I am logged in as wcadmin. And in case it matters, the State of the CAD Part is "In Work" (LifeCycle = Basic).
If you can think of any other situational aspects to consider in order to successfully MOVE from ProductA to ProductB, do tell.
TIA.
Is wcadmin a member of the Organization (check using Site Principal Admin)?
Is wcadmin the administrator of the Organization?
Can only move from ProductA to ProductB if the lifecycle is the same for both - but the contexts should be available to select.
For regular user, Move permission from Product to Product is granted by: Change Context (leave where it is) plus Create by Move (enter where it needs to be). But this should not affect wcadmin.
