Intralink 9.1 implementation questions
JosephCugini
I am on week two of my Windchill e-learning exercises and product
install/configuration/3.4 migration. As I see from the post of many
folks on the exploder, the more you learn the more you question.
Previous threads seem cover most of the newbie questions. I am however
curious what others think about the following.
Thank you in advance for your replies.
-Joe
* Our plan is to implement Intralink 9.1. Primarily because we
can maintain our concurrent license model and so that we don't have to
pay for Oracle separately since it was originally bundled with Intralink
3.4. Is this the same for others implementing Intralink vs PDMLink?
* How many products/libraries did you implement? If we were to
mirror our 3.4 folder structure I'd have 5 products (representing our
business areas) and 1 library. Inside of each product there would be a
folder structure that represented our individual programs. Our access
control policies would be the same for all products and we do not
restrict access of any of our engineers between programs. We'd utilize
the same basic lifecycle for all context. Considering these facts I'm
having a tough time understanding why I'd implement separate product
context for every one of our programs (as PTC typically suggests). It
just seems like that will lead to excess administration down the road.
* At what context did you implement your access control
policies? At the product/organization/site? From my limited
understanding, each context inherits policies from its parent. It also
appears that the policies are duplicated at each level when a new
context is created. So, if I plan on having the same ACP's for all
contexts does it make sense to implement my changes at the organization
level and delete the ones from the individual context?
> install/configuration/3.4 migration. As I see from the post of many folks on the
You can't imagine... You are just getting started. You need to be willing to
endure copious amounts of:
- Learning
- reading
- searching this Solutions list
- experimenting with an infinite number of combinations of Windchill properties,
java settings, Oracle settings, Vaulting combinations, Apache settings, Tomcat
settings, Life Cyles, Work Flows, Access Policies, Roles, Teams, Contexts,
Templates, and etc (much etc...)
- late nights
- Learning (Did I already mention that?)
> most of the newbie questions. I am however curious what others think about the
> following.
> -Joe
> ·Our plan is to implement Intralink 9.1. Primarily because we can maintain our
> concurrent license model and so that we don’t have to pay for Oracle separately
> since it was originally bundled with Intralink 3.4. Is this the same for others
Migrating from Ilink 3.4 to Intralink 9.1 or PDMLink 9.1 is about the same
amount of migration/configuration work. And the same amount of training needed
for your users. I think if you add up the migration/configuration and training
cost you will see that it far out weighs extra cost of Oracle (PDMLink) vs
Oracle (Intralink).
Plus you get a lot more functionality in PDMLink.
So why bother with Intralink? That was our reasoning for going to PDMLink.
> ·How many products/libraries did you implement? If we were to mirror our 3.4
> folder structure I’d have 5 products (representing our business areas) and 1
> library. Inside of each product there would be a folder structure that
> represented our individual programs. Our access control policies would be the
> same for all products and we do not restrict access of any of our engineers
> between programs. We’d utilize the same basic lifecycle for all context.
> Considering these facts I’m having a tough time understanding why I’d implement
> separate product context for every one of our programs (as PTC typically
> suggests). It just seems like that will lead to excess administration down the
> road.
We implemented a Context for each team as opposed to each product. There are
many viewpoints on this subject.
> ·At what context did you implement your access control policies? At the
> product/organization/site? From my limited understanding, each context inherits
> policies from its parent. It also appears that the policies are duplicated at
> each level when a new context is created. So, if I plan on having the same ACP’s
> for all contexts does it make sense to implement my changes at the organization
I went with the "remove access policies from Product/Library context and put
them at the Organization level" philosophy. Much easier to maintain.
What you want to do is create a Product template and a Library template that
have these access policies removed (along with all the other settings you
want for the default). Then use these templates for creation of new products
and libraries.
Randy Jones
Systems Administrator
Great Plains Mfg., Inc.
1525 E North St
PO Box 5060
Salina, KS USA 67401
email: -
Phone: 785-823-3276
Fax: 785-667-2695
