Invoking windchill SOAP call from VB.NET
Saravanan
Hello All,
We deployed a SOAP call for retrieving the ECN information.
We deployed a simple java client for invoking the SOAP call and able to retrieve the ECN information. When we attempt to retrieve the information using VB.NET, we get authorization required (401) exception. We used the same username and password credentials for both the cases.
The following WSDL url
7 REPLIES 7
you need to autheniticate the browser:
aBaseSession.AuthenticateBrowser(userName, userPassword)
Well,
what I wrote in last email is true if you are invoking from a ProE session but if not then maybe this will be of help:
Dim myCredCache As New CredentialCache()
myCredCache.Add(New Uri("http://some.site.com"), "Basic", New NetworkCredential(userName, userPassword))
client.Credentials = myCredCache
Hello All,
We tried with C# also for invoke the web service call and find the below snippets. The VB code will be basically the same minus the semi-colons. Any help would be appreciated.
com.vce.plm.IESoapServlet t = new com.vce.plm.IESoapServlet();
string tFoo = t.jwsinterface("10-0891", ", ","wt.change2.WTChangeOrder2");
Hello All,
Please find the below full C# code.
t.UseDefaultCredentials = true;
System.Net.NetworkCredential tCreds = (System.Net.NetworkCredential)t.Credentials;
tCreds.UserName = "ws_test";
tCreds.Password = "ws_test";
t.UseDefaultCredentials = false;
t.Credentials = tCreds;
We get authorization required (401) exception. Any help would be appreciated.
jmomber
(To:Saravanan)
HttpWebRequest request = (HttpWebRequest .Create(pubMonUrl);
UTF8Encoding
request.Headers["Authorization" .ToBase64String(credentialBuffer);
// execute the request
)request.GetResponse();
~Jamie
Microsoft support site recommends two approaches for surpassing this issue.
Thank you for all your reply.
The below code works for me.
IESoapServlet tProxy = new IESoapServlet();
tProxy.PreAuthenticate = true;
tProxy.UseDefaultCredentials = false;
System.Net.CredentialCache cache = new System.Net.CredentialCache();
cache.Add(new Uri(tProxy.Url), "Basic", new System.Net.NetworkCredential("ws_test", "ws_test", "));
tProxy.Credentials = cache;
string tFoo = tProxy.jwsinterface("10-0891", ", ", "wt.change2.WTChangeOrder2");
