Is it possible to retrieve Classification nodes with hierarchy and attributes in an report through an API like info*engine?
aklingvall
Is it possible to retrieve Classification nodes/tree with hierarchy and attributes in an report through an API like info*engine?
1. You can fetch all the classification nodes in QueryBuilder using table LWCStructEnumAtttemplate
2. The Node Hierarchy can be retrieved using below code snippet:
buf = getNodeHierarchy(<Internal name of node>,
     CsmConstants.NAMESPACE, new Locale("en"));
public static StringBuffer getNodeHierarchy(String paramString1, String paramString2, Locale paramLocale)
  throws WTException
StringBuffer buf = new StringBuffer();
String delimiter = "/";
TypeDefinitionReadView localTypeDefinitionReadView1 = TypeDefinitionServiceHelper.service.getTypeDefView(AttributeTemplateFlavor.LWCSTRUCT, paramString2, paramString1);
  buf.append(paramString1);
  buf.append(delimiter);
  if (localTypeDefinitionReadView1 != null)
  ObjectIdentifier localObjectIdentifier = localTypeDefinitionReadView1.getParentId();
  while (localObjectIdentifier != null) {
TypeDefinitionReadView localTypeDefinitionReadView2 = TypeDefinitionServiceHelper.service.getTypeDefView(AttributeTemplateFlavor.LWCSTRUCT, Long.valueOf(localObjectIdentifier.getId()));
  buf.append(localTypeDefinitionReadView2.getName());
  localObjectIdentifier = localTypeDefinitionReadView2.getParentId();
  // return localStringBuilder.toString();
  buf = removeSlash(buf);
return buf;
public static StringBuffer removeSlash(StringBuffer buf) {
String str = buf.toString();
if (str != null && str.length() > 0
&& str.charAt(str.length() - 1) == '/') {
str = str.substring(0, str.length() - 1);
final StringBuffer bufrt = new StringBuffer();
return bufrt.append(str);
3. Classification attributes for a node can be fetched through :
public static List<String> getPartsLinkIBA(String node)
throws WTException {
List<String> l1 = new ArrayList<String>();
final TypeDefinitionReadView localTypeDefinitionReadView = TypeDefinitionServiceHelper.service
CsmConstants.NAMESPACE, node);
if (localTypeDefinitionReadView != null) {
final Collection<AttributeDefinitionReadView> x = localTypeDefinitionReadView
final Iterator<AttributeDefinitionReadView> it = x.iterator();
// getting all the attributes internal name
while (it.hasNext()) {
final Object object = (Object) it.next();
final AttributeDefinitionReadView adrv = (AttributeDefinitionReadView) object;
l1.add(adrv.getName());
return l1;
