No luck so far with the service (PreferenceService2) setvalue methods. I see they are there but I must be misreading the method signatures. I'd like to try to allow the users to set preferences through a web page (to enable other validation, etc. niceties).
Ah. So right wrong or indifferent, setting preference worked with:
| PreferenceHelper.service.setValue("<INTERNAL PREFERENCE NAME>","<CLIENT NAME>", "<UPDATED VALUE>", <CURRENT WTUser>); | ||
But (FYI) I don't see this as a supported call according to the javadocs.....
I've been using PreferenceHelper.service for a year in 10.2 M030. It is called nearly daily.
You're right - it is not marked as supported. But it seems to be working. Just do careful testing whenever upgrading.
Shirishkumar Morkhade and I put some code around this for both getValue() and setValue() back in February 2016. My support case is C12653301. I know you can't view that ... but Shirish could view if he wanted to refer back to it and add anything else to this message.
