Anyone have experience using Jasper report dedicated queues? I've found this link: https://support.ptc.com/help/windchill/r13.1.1.0/en/index.html#page/Windchill_Help_Center/customization/WCCG_BusLogicCust_ReportGeneration_DedicatedQueueJasperReportScheduling.html
However when I follow the instructions the queues are not created automatically after restarting Windchill. Not sure if there are other properties that need to be in place?
So the resolution was this:
I needed to create a saved report and then create a data monitor for the report.. When I executed the data monitor for the first time the queue was automatically created.
Hi
Thank you for your question.
Best regards,
Did you try creating the queue yourself? I think the command is just making the association. It could assume that the queue exists. Try that.
Hi. Yes I did try creating a queue myself. I don't believe it is working. But I'm working with a PTC ticket. The issue may be I need a data monitor via a saved report which I wasn't doing. I'm still working it.
Hello @Tom_64,
It looks like you have a response from a community champion. If it helped you solve your question please mark the reply as the Accepted Solution.
Vivek N.
Community Moderation Team.
