I am using Windchill MPMLink Release 12.0 and Datecode with CPS 12.0.0.2
Any time we use the function'Assemble As New Branch' of XBOM Transform we obtain an error on screen: java.lang.nullpointerexception.
I would look at the MS logs and find where the exception is written. Posting that section of the MS log would help people see what this is related to.
2023-10-16 09:57:52,894 ERROR [ajp-nio-127.0.0.1-8010-exec-7] com.ptc.cat.ops.server.DefaultOperationDispatcher mirko grimaldi - null java.lang.NullPointerException
at com.ptc.windchill.enterprise.associativity.asb.server.transform.TransformationClientServerInterface._buildModel(TransformationClientServerInterface.java:1386)
Hi @RL_10799214
You should provide full log error, several rows up and down around the error message from a server method log.
Usually the information around is interesting, not just the error line.
PetrH
Hi @RL_10799214
Error while populating down stream part is path : java.lang.StringIndexOutOfBoundsException: String index out of range: -1
this error shows that some string value is empty or null, and that's why the error is thrown
Check OIR rules, there can be trouble with some conditions or some attribute is not shown in the wizard and it needs a value - check type and attribute layouts
PetrH
Hi @RL_10799214
Check the method server log, there is more information why there is null point exception as avillanueva mentioned
Anyway first think what came up in my mind is if you've correctly set the lifecycle, does the design object have a revise transition in the current state of design? it can case similar behavior.
CS387606 - Unable to create a New Downstream Branch
knowledge base next issue
CS357621 - 'NullPointerException' observed upon 'Paste as New Branch' in 'Occurrence Mode'
PetrH
