I receive three emails every morning at 4:17 AM. First one states that the method server stopping, message is "JMX connection to method server
'BackgroundMethodServer.1388' failed". The second one states the "Method server 'BackgroundMethodServer.1388' removed" and third one Servlet Engine Stopped: Java process removed: 1388@MAPLM. How do I go about troubleshooting? This just started about ten days ago when the windchill server was rebooted.
Thanks for any info you can provide!
Joanna
It looks like you bgms process is stopping everyday at the same time. Since this happens at the same time, I think it would be backup script or some server script which is rebooting the server at that time. If it is a windows server, could you look for uptime of the server ? More specifically you can look for eventviewer events for windchill services? Also the task scheduler
If it is unix based host, then uptime command ps -eo pid,comm,lstart,etime,time,args | grep 'PID' is very useful.
Binesh
Barry Wehmiller
Since it's the BGMS that's stopping, it's also possible that the cause is a scheduled queue entry that is running at the same time every day and causing a fatal error. Does the BGMS log from the stopped process show any errors just before it stops?
Joanna,
Were you able to determine the cause of the BGMS stopping every morning?
