Usecase:
I have an MVC Table like following:
Is there a way to implement a Javascript function that calls an Action on doubleclicking a row in the first column.
It should call the same Action like the following one:
Alex
HI Alex,
Hope you are fine.
Why don't you use in an easier way the follwing :
I'm not aware of a double click. Would be cool if that works. Have you opened a ticket at PTC?
Perhaps you can register your own table event. Have you checked the JS documentation?
