Jsp tag dateInputComponent
VasiliyRepecki
Hi.
I'm using jsp tag dateInputComponent (from http://www.ptc.com/windchill/taglib/wrappers library) to create date editor.
How can i get data from this editor in jsp?
Thanks.
I found.
request.getParameter("null___XXX_col_XXX___textbox") returns value from date editor.
XXX - is name attribute of tag.
Can anybody tell me, what is null substring in parameter name?
I found.
KD
(To:VasiliyRepecki)
If using HTML tag for input, the tag name must be following style for being read at NmCommandBean. “null___[attribute name]___textbox” If you want to use combo box, you must set name like following for NmCommandBean. “null___[attribute name]___combobox”
Kaushik
