Link/Shortcut object type to point to a shared network folder?
LawrenceS
18-Opal
Does anyone know how to create a link within a PDMLink document folder to a network folder outside of PDMLink?
I know how to create links to other websites, but would like to create one to related shared network folders.  When I try to it always inserts the prefix http.. in front of the network location, so it doesn't work.  In addition, users have permission to create or delete link objects, but users cannot edit them!
Any ideas?
"When you reward an activity, you get more of it!"
LoriSood
23-Emerald I
(To:LawrenceS)
You should be able to use UNC paths as link values.
Add the file:// protocol to wt.util.protocolsForHRefs property as per https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS134794 and then use file://<servername>/<path> as the link.
Example:
file://mycomputer/sharedFolder
file://mycomputer/sharedFolder/test.txt
LoriSood
23-Emerald I
(To:LawrenceS)
Example:
Thank you very much Lori!  That worked both with the UNC path and the letter path.  For example the equivalent of this worked on the network drive j:\
file://j:\test_folder\test_folder2
Now I just have to remember the syntax (and everyone else too.  To bad that it doesn't have an option on the setup screen so we wouldn't have to remember this text...
Another question about these links.  Users have permission to create and delete the links but not permission to edit.  We tried finding where to change the permission for these links but never found it.  Can you let us know how we can allow users to edit links after they create them?
Thanks again!  Lawrence
LoriSood
23-Emerald I
(To:LawrenceS)
I have investigated this for other customers, and the following article should help with that: https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS191736
Per https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS226178, some changes will be made such that admins and creators will be allowed to edit links (tentatively planned for 11.0 M010).
Thanks for the reference and the update on this Lori.  Yes, that will be a welcome change as the current permissions do not make sense from a user perspective.
Thanks again! 🙂
