Load File from Local
Amirtharaj_K
Hi Guys,
I am looking for existing local files that, how we can upload into Windchill through the LOAD FILES option.
Point 1: How we can create this excel sheet.csv?
Point 2: How we can convert into XML.
Aj
Hi @Amirtharaj_K
This is a live example
BeginMPMWorkCenter,,PA0001,WorkA001,make,,WorkStation,,/Default/Centers,Basic,Manufacturing,,INWORK,com.ptc.windchill.mpml.resource.MPMWorkCenter,,A,,,,,,
IBAValue,Parametr1,AAA,,
IBAValue,Parametr3,CCC,,
IBAValue,Parametr5,CDA,,
EndMPMWorkCenter
Create TXT csv file,
Use csvToxml tool from Windchill Shell CMD
check the XML output,
load this XML to windchill
how to use csvToXml tool https://www.ptc.com/en/support/article/CS358782
how to use load from file utility https://www.ptc.com/en/support/article/CS138169
All you can find on knowledge base
example with WTParts https://www.ptc.com/en/support/article/CS17492
example with wtDocument and primary file https://www.ptc.com/en/support/article/CS38296
PS> you can use load from file utility for all objects that are mentioned in the csvmapfile.txt
PetrH
21 REPLIES 21
Fadel
22-Sapphire I
(To:Amirtharaj_K)
we have below file with csv pattern
the conversion to xml is done by csv2xml tool https://www.ptc.com/en/support/article/CS358782
Fede
Amirtharaj_K
(To:Fadel)
Thanks for the reply, @Fadel. I apologize for the delayed response.
Do you have any sample XML and Excel files for me to understand?
Aj
Fadel
22-Sapphire I
(To:Amirtharaj_K)
Salam Amir,
would you let me know about the data you want to load , can later make a practical example
BR,
Fadel
Fede
Amirtharaj_K
(To:Fadel)
Alaykumu s-salam  @Fadel Thanks for the replay..
For example:
Scenario;1 I have a file like .sym, .frm, doc, excel & etc.. (I saved all my data path in excel sheet - A1 is Path and B1 is File name)
Scenario;2 Multi folder creation through loader in one Product/Library
Aj
Hi @Amirtharaj_K
The csv2xml tool will generate the XML for you from csv file.
here is the row with names with separator
user,name,number,category,description,standardProcessPlan,defaultUnit,folder,lifecycle,view,teamTemplate,lifecyclestate,typedef,parentContainerPath,version,iteration,organizationName,organizationID,createTimestamp,modifyTimestamp
Not all input have to be filled in but you can check DTD definition what is required.
...\Windchill\codebase\registry\ixb\dtds\standard12_1.dtd\csvmapfile.dtd
elements with question mark in the end of string attribute name are not required.
here is example with MPM WorkCenters with IBA definition
EndMPMWorkCenter
csvmapfile.txt contains this definition
BeginMPMWorkCenter~create~com.ptc.windchill.mpml.resource.LoadResource.beginWorkCenter~user~name~number~source~defaultUnit~category~usage~folder~lifecycle~view~teamTemplate~lifecyclestate~typedef~parentContainerPath~version~iteration~organizationName~organizationID~createTimestamp~modifyTimestamp~erpValidationCode~external~description
PetrH
Thanks for the replay @HelesicPetr Can you provide a live example that I can understand better and how extreme we can use the 'Load File'?
Aj
Hi @Amirtharaj_K
EndMPMWorkCenter
PetrH
@HelesicPetr  Thanks for sharing,
If i create individual means it's working, but how i can add the attachment individually in primary and secondary content. Refer the below attachments.
I already upload few data through creo, it's shown other format can we do this format in loader.
Aj
Hi @Amirtharaj_K
The objects loaded throw creo is not WTDocument so you can not use this method load from file to load EPMDocuments.
PetrH
@HelesicPetr  Thanks for the replay and could you help me with first line.
@Fadel
Aj
@Amirtharaj_K
What is not clear in the article CS38296
PS> the order is very important.
BeginWTDocument
EndWTDocument
ContentFile
BeginWTDocument
EndWTDocument
ContentFile
PetrH
@HelesicPetr It's a little confusing for me whether I can dump all the files in a zip file or individually. Because there we can see Test.zip,Test2.zip & ,...
Aj
zip is a primary content and the attachment is also zip file in the article example
What is confusing?
You need to define each file individually
BeginWTDocument - defines the object in the Windchill
EndWTDocument - defines the primary content file
ContentFile - defines the attachment file. You can use more ContentFile rows for more attachments but it has to be before next BeginWTDocument definition
the definition order is super important
PetrH
@HelesicPetr
Point:1 I want like one document will create & the Name: T1 and 2 attachments have one for Primary and other one for Secondary. Similar for T2, T3 & T4 i have a document for that also.
Point:2 Here which i confused all document is dump in zip and stored only in one Document or individual like T1, T2, T3...
Aj
@Amirtharaj_K
What all documents in dump are you talking about?
The source files has to be individually placed in a folder not in a one zip file.
PetrH
@HelesicPetr
I think this will help us to understand what i asked.
I create multi-document that name are T1 |  T2 | T3| T4
Each document have a some attachments okay, Example T1 have 2 Attachments one for T1.txt (Primary) and other one is 888505.xlsx (Secondary)
Question: How we can go similar for T2 Document. (Attachments is different)
Question: T3 i can use T4.txt & 888508.xlsx, how we can map it.
Aj
Thanks for the Quick reply @HelesicPetr
For example, I have 1000 documents and I need to go with this order individually for each document, right? It's definitely a challenge to create on this structure, isn't it?
Reagrds,
Aj
Hi @Amirtharaj_K
It is not so big deal if you can define all definitions in one row.
T1 number, name, primary file location1, 1attachement file1, 1attachement file2, 1attachement file3
T2 number, name, primary file location2, 2attachement file1, 2attachement file2, 2attachement file3
TX number, name, primary file locationX, Xattachement file1, Xattachement file2, Xattachement file3
then you can write a code in excel that creates the structure definition as you need based on the csvmapfile.txt
then you just save the result to the csv file.
I did it many times.
Also you can write own utility that can build the Windchill correct structure from you specific input.
For someone who can not create any automatization by code it is challenge.
PetrH
@HelesicPetr Thanks for the reply
For the testing purpose i test it's not work T1 only have attachments other's doesn't have. Kindly correct me if i done a wrong thing.
How we can add the attributes on here.
AJ
Hi @Amirtharaj_K
don't use the empty lines(rows).
PetrH
Thanks @HelesicPetr  It's working. You taught me something new.
