I am in the process of upgrading our development from Windchill 9.1 M060 to Windchill 10.1 M030 and ran into an issue with our load files for soft types. I took our v9.1 load files and converted them to the 10.1 format following the example files provided with the installation. The IBAs referenced in the soft type definition have already been loaded via a different load file without errors. When I try loading my soft type, I get an error: "Cached type attribute list is null!". I'm trying to determine what the problem really is. I compared my load file with the example load file and it looks like the same layout and format. I'm looking for any advice on where to look or what changes need to be done in order for this file to load. I've attached an example load file for our IBAs, the load file as it was in 9.1, and the load file as I converted it to be used in 10.1. I've also included a snippet from the MethodServer log.
