Would like to fully understand what are the pro and cons for Downstream View and Downstream Part.
Does anybody us the mBOM productivly ? What methode do you use and why ?
Thank you very much
Klaus
Assuming Upstream as "Design View" and downstream "Manufacturing View"
MPMLink provides function called "New Branch" in MPSE in 10.2 or MPSB for 11.0+
Branches are splits in an object's version tree which enables users to work on parallel or alternate design paths. New branches can be created for parts, process plans, operations and sequences and is a key tool to use during BOM transformations, or when creating associative BOM links.
