Hello
is there a way to select several WTDocument (same subtype) and change the same attribute for all at once ?
It is possible for the EPMDocument, but we can't find a way of doing it for WTDocument.
Thanks in anticipation
Best regards
Hi Wilson
you wrote:
You can do this with Edit Multiple Objects function which is available in PDMlink 9.1. This is by default available in the product folder location. We have also extended the link to our Change Activity objects so that it can be used there as well.
Thanks for the information. I should have mentioned we have 9.0 but are planning to update to 9.1 in a few weeks. So this should be straightforward then
