I seem to be able to run the Windchill Vault Content Check report (windchill wt.fv.tools.WContentVerify) one time and it completes OK. If I then run it again without restarting Windchill, I get an "Out of Heap Space" Error and the Methodserver crashes so the Server Manager starts another Methodserver - which causes problems as the original Methodserver is still attached to the network sockets and the new one hence does not function properly.
Is there some command that I can run to clean up the Heap in the original Methodserver so that I don't have to restart Windchill before running the Vault Content Check report again?
Rds
Gary
