hello,
I am working on migration of Intralink 3.4 to PDM link9.1 M050 with Data Migrator
9.1 M050 .
when I test connection between Source and Targetit returns
com.ptc.migration.util.MigrationException: database link pdmlink_wind_TestDBLinkCreation created in this step could not successfully access the remote database
Anyone does have any idea?
detail error log:
Main Menu
Although
In addition to that when I when move forward to next steps without testing connection Download Admin Data, Reconcile admin Data, Load Admin Data all option with its sub option works fine(Library folder’s ,user ,Attributes are created on target system as they are on source)
But when I Map Admin Data it gives same error
com.ptc.migration.util.MigrationException: database link pdmlink_wind created in this step cound not successfully access the remote databaseError log as follows:
Main Menu
1: Test Connections
2: Download Admin Data
3: Reconcile Admin Data
4: Load Admin Data
5: Map Admin Data
6: Create Document Migration Rules
7: Pre-configuration for Part Creation
8: Cleanup Mapping
9: Exit pre-configuration.
>>> Choose an option: 5
User selected:5:Map Admin Data
This step will map administrative data between Pro/INTRALINK and target system.
You can perform the following operations.
1: Create Migration Site
2: Map USER data
3: Map FOLDER and RELEASE SCHEME/RELEASE LEVEL data
4: Map USER DEFINED ATTRIBUTES data
5: Map FILESERVER data from Pro/INTRALINK
6: Map ALL data (includes Migration Site creation)
7: Go back to the main menu
8: Exit pre-configuration.
>>> Choose an option: 1
User selected:1:Create Migration Site
01/11/2010 18:43:36 INFO admin.MigrationSiteLoader - ilDomainId:XXXXXXXXXXXXXXXXXXXXXXXXXXXX
01/11/2010 18:43:49 ERROR util.MigrationException -
Nested exception is: java.sql.SQLException: ORA-12545: Connect failed because target host or object does not exist
at oracle.jdbc.driver.SQLStateMapping.newSQLException(SQLStateMapping.java:119)
at oracle.jdbc.driver.DatabaseError.newSQLException(DatabaseError.java:134)
at oracle.jdbc.driver.DatabaseError.throwSqlException(DatabaseError.java:254)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:467)
at oracle.jdbc.driver.T4CTTIoer.processError(T4CTTIoer.java:417)
at oracle.jdbc.driver.T4C8Oall.receive(T4C8Oall.java:1088)
at oracle.jdbc.driver.T4CPreparedStatement.doOall8(T4CPreparedStatement.java:215)
at oracle.jdbc.driver.T4CPreparedStatement.executeForDescribe(T4CPreparedStatement.java:1038)
at oracle.jdbc.driver.T4CPreparedStatement.executeMaybeDescribe(T4CPreparedStatement.java:1145)
at oracle.jdbc.driver.OracleStatement.doExecuteWithTimeout(OracleStatement.java:1471)
at oracle.jdbc.driver.OraclePreparedStatement.executeInternal(OraclePreparedStatement.java:3888)
at oracle.jdbc.driver.OraclePreparedStatement.execute(OraclePreparedStatement.java:4077)
at oracle.jdbc.driver.OraclePreparedStatementWrapper.execute(OraclePreparedStatementWrapper.java:3192)
at com.ptc.migration.admin.MigrationSiteLoader.map(MigrationSiteLoader.java:77)
at com.ptc.migration.admin.MigrationInteractive.performAction(MigrationInteractive.java:440)
at com.ptc.migration.admin.MigrationInteractive.runMenu(MigrationInteractive.java:316)
at com.ptc.migration.admin.MigrationInteractive.performAction(MigrationInteractive.java:351)
at com.ptc.migration.admin.MigrationInteractive.run(MigrationInteractive.java:287)
at com.ptc.migration.admin.MigrationInteractive.<init>(MigrationInteractive.java:267)
at com.ptc.migration.admin.MigrationLoadingTest.main(MigrationLoadingTest.java:132)
at com.ptc.migration.admin.MigrationLoadingTest.Main(MigrationLoadingTest.java:163)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
at java.lang.reflect.Method.invoke(Method.java:597)
at com.ptc.migration.bin.ILDataloader.execute(ILDataloader.java:136)
at com.ptc.migration.bin.ILDataloader.main(ILDataloader.java:113)
01/11/2010 18:43:49 ERROR bin.ILDataloader - ORA-12545: Connect failed because target host or object does not exist
C:\ptc\ILMigration\bin>
Shreyas
