Modifying the OOTB Change Notice Workflow
pwilliams-3
10.1 M040
Hi Everyone,
I have made a copy of the OOTB CN Workflow and am modifying it to use custom roles instead of the CA I/II/III roles. I have been able to find the places where CA I and CA III are used but I cannot find all the places where CA II is used. I know it is being used somewhere in the WF because it is listed in the Role Setup tab of an Assignment Activity. Does anyone have a way to find all places where this role is used?
[cid:image001.jpg@01CFD73B.BD46CD90]
Patrick Williams | Engineering Systems | c: 616.947.2110
[cid:image002.jpg@01CFD73B.BD46CD90]
Look in:
- All WF emails
- All WF activities
- All states in the relevant PBO type Lifecycle
Export it. Open zip file and search on resource bundle key equivalent inside XML file.
Sent from XFINITY Connect Mobile App
If you want to replace the CA/I/II/III roles with customer then export Workflow (zip). Open XML file from Zip. Replace CA/I/II/III with custom roles (use internal name of the role ) and re-import zip file.
shreyas
Thanks everyone for the ideas. I missed an email that still had CAII.
[cid:image001.jpg@01CFD749.95AA8AC0]
