Hi All,
I've a requirement which asks to move objects of a certain type from one product to another product while creation. For example, if I created a WTPart in Product A, it should get stored automatically in a given location within Product B.
I'm not sure how to enable such move action within inter context movements. How can we achieve such scenario?
Thanks in advance.
Wasim
I think this can be acheived by adding a custom workflow to the WTPart object and from there you can check where that is getting created,according with that you can assign a Folder location for that part
Hi Vigneshwaran,
I appreciate your reply. Could you please provide a logic or example to achieve this? I think there should be a listener required to listen to creation of WTParts?
Wasim
I don't think you need any listener or service to capture the creation of WTParts.Since you are adding that inside the custom workflow for wtpart,add a expression robot and specify your folder path there.
This API will work to assign the location.
FolderHelper.assignFolderByReference(part, oRef);
Here oRef is ObjectReference
Hi Vigneshwara,
Sorry for a late posting. I am able to figure out the type of object. When a WTPart is getting created, we'll move it. However, the code is not working for me.
Could you please help me with a snippet or exact code required to move an object from one context to another?
I tried to use getFolderPath but it doesn't work with 10.1.
Thanks in advance.
Wasim
