Dave,
This is a topic that is of interest to me also...
How do you suggest using the Applet export/import as, if you export the data from the PROD System, surely you will not be able to import the same data into the TEST system as it will already exist in the DB (but not the vault)? If you were to just copy the vault files from the resulting exported jar file then I am guessing that this would not work either as the filenames will all be wrong.
Or am I missing something here?
Would you be able to expand on your SQL report method to grab an assy's vault files so that they can be manually copied and point me to the utility class and how to use it?
Thanks in advance
Gary
