Moving objects from a Product/Folder to another with the java API
fbaumann
8-Gravel
I'm looking for the best way to move EPM documents and attached WTParts from a product container to another and/or from a folder to another with the JAVA API (remotely and in a workflow robot).
Should I use the setContainer() method from the initialized EPMDocument? Is there a specific Helper avalaible?
I would like also to do it from the client-side...should I find a solution with the JCA interface (ActionModel interface).
Thank in advance
Fabrice
You can use webject changeIdentity
