Need help with workflow expression and logging
psernetz
I am currently editing a workflow for a customer and I want to use log4j. The customer uses PDMLink 10 and I´ve defined the logger inside the workflow expression like that.
org.apache.log4j.Logger logger = org.apache.log4j.Logger.getLogger("com.ps.test");
logger.info("Info from com.ps.test");
logger.debug("Debug from com.ps.test");
logger.error("Error from com.ps.test");
when initiat this process I can see the error message on stdout. But I am not able to get info and debug to show up. So I´ve created a configuration for this with the Log Levels tool inside the System Monitoring menu.
I´ve defined the server process method and servlegt engine and set the logger to com.ps.test. After that I´ve selected the level all and hit set.
But still no luck. I just want to be able to control the logger output from my workflow expression.
Any ideas, I am pretty sure I am missing something and I have not really found a good explanation on this...
Please help
Patrick
0 REPLIES 0
