New application Help
anis
Hello ,
I'm new in windchill and i have to connect it with other application, the aim is to import files from this application to windchill from distance
I'm new on this and i want to know from where shoul'd i begin and if you have some useful docs i will be very gratefull
Should i use info*engine? PDM Link ? create a web server ? create a j2EE or J2SE application ?
Please i need a little help
Anis
MatthewKnight
(To:anis)
The question's a little vague.
If it's a one time deal, you could export to an xml/csv and write a loader to be called from WC. Or you could do a direct jdbc (assuming the source is in a db). Generally, you want to go through WC's Persistence layer, but if you know what you're doing, direct db manipulation can work.
Are you pushing? Maybe use Info*Engine tasks.
Are you pulling? Use Windchill's java api and a custom queue.
There are many options
Hello Matthew,
Thanks for your answer.
Let me explain more what i need,
In fact, i have other application X (not a CAO application) and i need it to be integrated with WC.
Files from X running on a PC should be exported to windchill that run in other PC so i need to know what should i do and what shoud i use
Configuration:Windows SQL Server 2003, Apache Tomcat
Tahnks
Anis
If I am understanding you correctly, I think you are asking about possible file types that WC will allow you to import from.
If this is the case you can do a loadFromFile from within a windchill shell on Excel type files like csv.
anis
(To:JacobAKoch)
yes i tried with loadfromfile but it works only with csv files i need to import other types (.txt, .scy....) besides the files are in othe PC so Should i develop a web service to export files from an application to Windchill that run in other application?
