Hi Everyone,
I'm being asked by my manager to provide info regarding the number of items in Intralink. Is there an easy way to find that out? My guess is that the easiest way would be thru an Oracle query of some sort but I'm not sure. I haven't seen any other questions on this subject. Most questions have to do with table space or cluster size. We need to find out because they're considering using SAP instead of IL and the SAP won't tell us how much it will cost until they know how much data is involved. Any help would be greatly appreciated.
Rich
Thanks everyone for the quick response! I've gotten a number of suggestions to do a "Locate" of some sort. This works as a quick check of the items in IL but my boss has already found more items that the "Locate" command has returned. We've got a purge scheme in place that keeps 3 versions of PIV's at each release level so we've got a lot of more data than first appears. I don't have access to the data server so I'm at the mercy of our IT group to set up and run a SQL script. My gut feeling is that the SQL script tool is going to be the most accurate. Thanks go to Patrick Williams for that PTC/VAR tool.
BTW, it's not my idea to go to SAP or Teamcenter. I was told flat out by a Siemens Teamcenter account manager that the best tool for managing Pro/E data is a PTC PLM product! And he sells Teamcenter!
Thanks again!
Rich
