OOTB to disable creating CN on an object which is present in the resulting objects of another CN
OP_11714882
8-Gravel
Hello, is there any OOTB functionality to disable creating a Change Notice on a version of an object which is already present in the Resulting Objects of another Change Notice?
Because it can be quite a common business requirement that if there is an ongoing change on an object, I don't want to add another change on it before completing one change.
Om Panchdhane
6 REPLIES 6
Fadel
23-Emerald I
(To:OP_11714882)
when an object is under change you have a flag for it :
if you have an issue with concurent changes, you may be interested in About Redline
Fede
But we can still create another change notice on it right? Is there any configuration to disable the CN creation?
Fadel
23-Emerald I
(To:OP_11714882)
Not OOTB , I can only think of customizing the the CN/CT workflow to move the affected objects to Lifecycle state with a set state robot to a state   where there is no change transition, defined , this should hide the action .
Fede
Okay. Thanks!
FelcoSolutions has their ObjectValidator app. It is intended for issues like this:
https://www.felcosolutions.com/objectvalidator
Thank You!
