Opening Pro/e maximized
Highlighted
Newbie
Is there an option to always open pro-e maximized rather than leaving the space to the right for the menu manager ?
Highlighted
open proe window maximized
Nathan, use the hidden config option open_window_maximized and type a value of yes. Note this is a hidden config option so it is not really supported by PTC. However, I have been using this option for years and have not had any real adverse affects yet. Occasionally, one of the menus will pop up behind the screen but you can double click on the bar on top of proe or minimise then maximise and the menu will become visable.
