Hello and thanks in advance for any insights...
(Platform is Windchill 9.1 M050 w/PDMLink, MPMLink, ProjectLink and Supplier Management installed, not all modules in use)
I discovered a number of "new" Change Objects that showed up in the Type and Attribute Manager with 9.1 and the (Search All Help) Documentation only refers to them as being "Optional" elements of Change management. OK, so how do they work and what does it take to get them working? What is the intended functionality? The list that follows includes some that were there with 9.0, any insights on these will also be appreciated;
- Analysis Activity (wt.change2.WTAnalysisActivity)
- Change Action (wt.change2.WTChangeAction)
- Change Directive (wt.change2.WTChangeDirective)
- Change Investigation (wt.change2.WTChangeInvestigation)
- Change Proposal (wt.change2.WTChangeProposal) - OK, this one I have bumped into before because I needed to grant access to this object for the Proposed Change field in the Change Request Object to be visible to users instead of showing as (secured information)
Maybe I'm not looking in the right place for information?
Thanks!
