Oracle Database import question
HK_10985243
2-Explorer
I am using Windchill PDMLink Release 11.1 and Datecode with CPS M020-CPS27
Can we import database using the following command: (This command has exclude=statistics)
impdp system/manager@wind directory=export dumpfile=EXPDP_acumedprd_19032023_01.dmp,EXPDP_acumedprd_19032023_02.dmp,EXPDP_acumedprd_19032023_03.dmp,EXPDP_acumedprd_19032023_04.dmp exclude=statistics LOGFILE=import_acumedprd.log schemas=acumedprd
And then run the following command as per article https://www.ptc.com/en/support/article/CS129969 to gather statistics manually:
execute dbms_stats.gather_schema_stats('DBUSER', DBMS_STATS.AUTO_SAMPLE_SIZE , CASCADE =>TRUE);
BenLoosli
(To:HK_10985243)
Here is what I do:
a. Export the current database with the expdp command and Windchill shutdown
expdp System/@wind schemas=PDM directory=expdp_full dumpfile=full_exp.dmp exclude=statistics logfile=full_expdp.log
b. Import the Oracle backup into the PDM user space
Impdp System/<password>@wind  schemas=PDM directory=expdp_full dumpfile=full_exp.dmp logfile=full_imp.txt
c. Gather DB Statistics
SQLplus PDM/<password>@wind
Execute dbms_stats.gather_schema_stats(‘PDM’,DBMS_STATS.AUTO_SAMPLE_SIZE, CASCADE =>TRUE
I do not see any reason your method should not work since in both cases the statistics are not part of the imported DB.
BenLoosli
(To:HK_10985243)
Here is what I do:
CHanna22
(To:BenLoosli)
Are you still dropping WCUSER before importing the new dumpfile?
BenLoosli
(To:CHanna22)
Yes
 Between step a and b, I do the following:
Drop user <pdm_username>
@create_user.sql - this will ask for 3 pieces of infomeation
PDM username
Temp Tablespace name - TEMP
Userdata Tablesapce name - USERS
