Folks,
Per Call number C7874751, PTC has told me that if one is publishing Pro/ENGINEER Drawings as PDF's in Windchill you cannot adjust the height of the font used to create notes in any annotation created.
I was told that product management's position was that the ability to edit the height of text in a Markup on a PDF should be an enhancement request.
I could almost live with not having control over the height of the font if the system was smart about picking the text height. However, I have found that depending on the size of the drawing one is trying to annotate the font could either be to small to read or so large it covers most of the drawing.
I hoping against all hope that someone has figured out how to adjust font height in product view for PDF drawings and if not that enough folks will reach out to their PTC representatives to pressure them to fix what is clearly and oversight on behalf of development and product management. (It was obviously thought necessary for markups of product view and HPGL files, because the text height of notes is adjustable in those.)
Sincerely,
Dan J. Dial
