If you had to do your migration from Intralink to PDMLink over again what would you do differently?
(Assume you were migrating to the current version where many of the technical challenges have been mitigated since its inception)
Did an out of box implmentation cause issues down the road where if you knew then what you knew now - you would do differently?
Did you have to consolidate of multiple intralink systems?
Would you source activity internally vs. externally, etc.?
What tools did you use and what was your level of satisfaction? PTC Data Migrator? Prostep? Other?
What gotcha's did you encounter either during the implementation or after as a result of poor up front planning.
Additional comments or suggestions?
