ERP (SAP and others...) are in most of cases are set up "without revision"
cause as you says, same part (ie sams number) is interchangeable. and can be mix in the same box in the stock.
Here we are touching the tricky part of the BOM management (I should more use the term of "Configuration Management")
for me , the way to deal with it , is to use Change Management, in conjonction with effectivities management (date and lot ...) . across the PLM and ERP system .... to keep in track the different BOM views ("engineering", "manufacturing", and may be "as built" and "as maintained ")
regards
Gregory
The SAP meaning of "Revision level" is certainly different than the PLM (in this case, Windchill) meaning.
At the part level, SAP has no true "Revision Level".. This is primarily due to the manner in which Engineering Change Management (ECM) is applied to materials. Note that this function (ECM) is either date or parameter driven... No concept of a "revision\iteration\date" as in Windchill.. That doesn't mean you cannot manage the revision.... You need to change how you think of it though...
In the SAP world, the Document Information Record (DIR) has a "Version"... This version can be changed with ECM. So one method of managing revisions without changing material numbers is to link the output document from Windchill (in our case, a PDF) to a DIR. In turn, this DIR is assigned (linked) to each relevant material. When the part in Widchill is revised, we will change the DIR to point to the new revision level output document as of a specific date (effectiviy of the new revision) and potentially "uprev" the version of the DIR. At that date,production orders referencing the material will pull the correct revision document, pointing to the correct revision in WIndchill.
Not a pretty solution, but it's where we are heading... We are not there yet, so any additional input would be greatly appreciated..
