Hi all,
I changed after a the installation path of the "ptc" folder from one Drive C to D. Right now i would like to install a component using PSI but when i start PSI it will point to the old installation path. Is there any way to change this?
Alex
You should make modification in psi_iir global file in your user profile, C:\Users\userwhoranpsi \AppData\Roaming\ptc\Windchill\psi_iir_index.xml and the psi_iir file from D:\PTC\Windchill_10.2\PSI\installer\instreg\registryfolderpathfromglobalfile\psi_iir.xml
