Partslink autonaming rule (if boolean attribute)
ArnaudGOELZER
I need help for creating an autonaming rule for a node (partslink). I can't write correctly a rule taking account an "if" function with boolean (yes/no)
Input data :
- "My part" (text)
- Attribute1 (boolean)
My formula :
"My part" + (attribute1==yes) ? "something" : ""
The second part of the formula doesn't work.
I'm trying to make him write that if the attribute1 is "yes" then write "something". Otherwise, don't write anything more.
Can anyone correct me ?
Arnaud
Hi Arnaud,
Currently, that feature does not support logic/arguments for Boolean Attributes.
The Autonaming feature supports:
Node Name, Attribute (alone), Strings, and Attribute w/ function (only for Integers and Real Numbers)
Nick
Hi Arnaud,
Nick
To add to Nick's response, there is a knowledge article as well,
https://www.ptc.com/en/support/article?n=CS257756
...that confirms Nick's information.
