I have a questions regarding setting documents attributes based on variables in a workflow. I have been able to pull the attributes of a document and set them as variables in a workflow, but was wondering if there is a way to do it in the opposite way? Is there any java code that will work in 10.2 to accomplish this? Lets say I have an approver signature in the workflow( That they filled out in the workflow) I need to take pass that signature back into the soft type?
Even I'm trying to achieving the same. Passing variable value to soft type attribute.
Any references.
Durga
Hi Durga,
If the mapping is between a workflow and the primary business object then another option for you could be to pass it using an alias attribute, there's examples on PTC support.
