Policy Administrator
ptc-171472
OK, I found Policy Administrator and I want to compare permissions on
different products and libraries
Is there any way to export, print or copy this data into Excel?
Black & Decker Hardware & Home Improvement
Michelle McMasters
Engineering Systems Administrator
michelle.mcmasters@bdhhi.com
Demonstrate Unyielding Integrity * Deliver on Commitments * Inspire
Excellence * Win through Teamwork
IMPORTANT NOTICE: This message is intended only for the use of the
individual or entity to which it is addressed. The message may contain
information that is privileged, confidential and exempt from disclosure
under applicable law. If you are not the intended recipient, you are
notified that any dissemination, distribution or copying of this
communication is prohibited. If you have received this communication in
error, please notify the sender immediately. Thank you
dwilliams
6-Contributor
(To:ptc-171472)
Michelle,
You can use the following report to export the ACL's by context or object type.
Thank you,
Dax
Can this report be run at the org level?
What syntax is needed for object and context
example: wt.doc.WTDocument
Any (Query Builder) report can exist at Site, Org or at a Product/Library, and can be exposed at any lower level. In general, all reports can be accessed the same at Site or Org.
